Getting False Result with Tone Measurement Express VI
Updated Jul 25, 2019
  • SignalExpress
When I measure a sinewave with Tone Measurement Express VI, I get an apparently wrong result (amplitude, frequency, phase). My input signal is a 1Hz sinewave, with Vpp 1V. With the Sampling Rate 10k and Number of Samples 1k, the measured frequency of Tone Measurement Express VI is 14~16Hz, and the measured amplitude is 0.02. What is the matter?
The reason is that the Tone Measurement Express VI measures a sine wave signal correctly only when the samples used for measurements consist of at least one full cycle.
To resolve that, you can either:
  • Increase the signal frequency to be larger than Frequecy Resolution (Sampling Rate/Number of Samples).
  • Increase the Number of Samples to include at least a full cycle.
  • Lower the Sampling Rate.
