NI Direct Injector Driver System Software Updater Process
Updated Jul 30, 2018
  • C Series Direct Injector Driver Module
  • Direct Injector Control and Measurement Device
I purchased an NI Direct Injector (DI) Driver System and want to update it to the most recent software. How do I do this?
Download the software installer that is appropriate for your system:
Current Controllers
9066 - based DI Driver System Updater
Legacy Controllers
9076 - based DI Driver System Updater
9022 - based DI Driver System Updater
You will also need to download the NI Software Calibration Management Toolkit for LabVIEW (NI SCM) to interface with your DI Driver System. For the 9066-based DI Driver System, you will need SCM for LabVIEW 2015; for the 9022 and 9067-based DI Driver Systems, you will need SCM for LabVIEW 2014.
