Formula Node in LabVIEW Not Giving the Expected Angle Information
Updated Jun 11, 2018
When using expressions such as tan(45), I do not get the expected answer of 1. How do I get the formula node to work correctly.
The formula node needs radian numbers as input.
If you would like to have degrees as input, use the degrees to radians function.
1. click Crtl + Space to open quick drop
2. Search Degrees to Radians
3. Double click the degrees to radians option
4. Drop it into your block diagram and wire it to your formula node.
