Can I Access the FPGA in the VST Using FPGA Interface C API Generator?
Updated Jun 9, 2018
  • PXIe-5645
  • PXI Vector Signal Transceiver
I am able to succesfully download a bitfle in the VST (5645R) using LabVIEW 2015 SP1.  I'm trying to use this same bitfile from a C/C++ environment using FGPA Interface C API Generator. The ".h" and ".c" files are properly generated but when I try to download the bitfile, I get the error -63101.
The FPGA Interface C API Generator does not provide support for the VST FPGAs.
The FPGA Interface C API Generator supports the following hardware:
  • NI CompactRIO
  • NI sbRIO
  • NI EthernetRIO
  • NI FlexRIO
  • NI R Series multifunction RIO
  • NI MXI-Express RIO
