How to Send Notification From TestStand UI to Sequence?
Updated Dec 5, 2019
  • TestStand
I need to send a tag data to the sequence from the TestStand UI and I want to do it by TestStand notification.
First you create the notifier in the TestStand sequence and insert a "Notification" step set on "Wait":
Then you have to create the LabVIEW code that send a notification from the UI, for example by creating a new Event in the Handle Event state of the UI Top-Level.vi:
