Incorrect Username or Password When Adding a New Remote Device in NI MAX
Updated Jul 22, 2026
When I attempt to add a new network device to NI MAX, that is not on the local subnet, I am prompted for login credentials. Entering the correct username and password generates the following message prompt:
Incorrect username or password.
Please try again.
I am able to log in to the remote target with the web configuration utility, and from NI MAX on a different computer.
This issue could be due to the network using a proxy server for HTTP requests. An environment variable "HTTP_PROXY" is set on the PC, that directs HTTP requests to the server defined in the variable. You can delete the variable and see if it resolves the issue.
Follow these steps to delete the Environment Variable:
  1. Open the Window Control Control Panel
    1. Navigate to System > Advanced System Settings > Advanced > Environment Variables.
    2. In the User Variables, find and delete the HTTP_PROXY variable.
  1. Re-launch NI MAX and add the target.
  • Alternatively HTTP_PROXY environmental variable can be overridden for the called application with this command
    • powershell.exe -Command { $env:HTTP_PROXY=""; & 'C:\Program Files (x86)\National Instruments\MAX\NIMax.exe'}
