Generating Citadel Historical Data Using LabVIEW DSC Module
Updated Nov 1, 2023
I want to generate historical data for my Citadel database. Can I add data with custom timestamps to my Citadel database by using the LabVIEW Datalogging and Supervisory Control (DSC) Module?
As explained in Logging Data with NI Citadel, you can write to your database by using shared variables, a DataSet Marking I/O Server, or the Citadel Writing API, all included with the DSC Module. In order to work with custom timestamps to enter historical data, you should use the Citadel Writing API.
LabVIEW ships with an example of how to do this. Navigate to Help»Find Examples»Toolkits and Modules»Datalogging and Supervisory Control»Data and Alarm Historical Logging. Choose Database Direct Write Demo.lvproj, which demonstrates how to write to a Citadel trace.
