cDAQ Module Compatibility with the NI USB-9162
Updated Apr 5, 2019
  • USB-9162
I am looking into purchasing a new cDAQ module for my NI USB-9162 single slots chassis. Are there any limitations on what cDAQ modules that I can use?
The NI USB-9162 is a legacy chassis that can only be used with specific cDAQ modules. Please refer to the C Series Module Compatibility Chart for a full listing of all cDAQ modules that are compatible with the NI USB-9162.
If you are interested in purchasing a new cDAQ module with the NI USB-9162, you should also consider NI-DAQmx driver compatibility with the NI USB-9162. Check the NI-DAQmx version's readme to confirm compatibility with the NI USB-9162.
