How Can I Set Up A Software Trigger For A Remote System?
Updated Jun 6, 2018
  • NI-9215
  • LabVIEW Real-Time Module
I am trying to set up a software trigger for a remote system, which is to be controlled via a user interface on my host system. How can I implement this in LabVIEW?
Yes you can use a network published shared network variable to send a boolean value through your network, that can then be used as a software trigger for your remote system.
For information on how to create a shared variable please see:
How to Set Up Shared Variables in LabVIEW to Communicate Between Two PCs
For information on how to use a shared variable see:
How do I Use Shared Variables to Communicate Between Two Computers?
Please note, that a software trigger will not be determinstic, so should not be use for applications with tight response and synchronisation requirements.
