How to Create Global Virtual Channel in NI-MAX
Updated May 25, 2026
  • DAQ (Legacy)
I want to create a Global Virtual Channel in NI-MAX, how can I do it?
virtual channel is a collection of settings such as a name, a physical channel, input terminal connections, the type of measurement or generation, and can include scaling information. A virtual channel created outside a task is a Global Virtual Channel. For detailed definitions and example codes, refer to Creating a Virtual Channel in NI-DAQmx and Using it in LabVIEW
Steps to create a Global Virtual Channel in NI MAX
  • Open Measurement & Automation Explorer (MAX) from your programs.
  • Right-click on Data Neighborhood and select Create New.
  • Choose NI-DAQmx Global Virtual Channel to open the wizard.
  • Follow the prompts to configure the channel:
    • Select an I/O type (e.g., analog input).
    • Choose the measurement or generation to perform.
    • Select the applicable sensor for that measurement.
    • Choose the physical channel from which to create the global virtual channel.
    • Name your new global virtual channel.
    • Configure any additional settings as necessary.
  • Save your configuration.
  • Optionally, verify your data in the window that opens after saving.
