Inter Byte Delay in Serial Communication
Updated Jun 5, 2018
  • PCIe-8431/8
  • NI-VISA
  • NI-Serial
I am using an NI Serial board to perform communication with the RS-485 protocol. Occasionally, I am seeing delays between output bytes. How can I prevent this delay?
The RS-485 communication protocol specifies that communication will occur at a specific baud rate, but not that this communication happens continuously. The time between packets of data is not specified, and depends on the UARTs being used.
