Error -1074360274 When Using Same Name for Multiple Cameras in NI MAX
Updated Jun 5, 2018
  • Vision Development Module
When attempting to name a camera in MAX I get the following error:
Error -1074360274 occurred at an unidentified location
Hex Code: 0xBFF6902E
Possible reason(s):
Unable to rename interface. Invalid or duplicate name specified.
How can I resolve this error?
There are a couple of different use cases where this error might occur. Please see below for the case that most closely matches your intended use.
Case 1: Using the same camera name for two cameras at the same time
This is not an option, as each camera in MAX must have a unique name. The recommended workaround is to iterate on the camera name in a predictable manner. (eg. camera1, camera2, etc.)
Case 2: Develop and deploy identical systems with identical camera names
If you have already deployed the system with the camera name you want to use, or no longer have a need for the previous camera with that name, you can free up the name by deleting the .iid file for the camera. These files can be found in the following location for Windows:
C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data
After deleting the .iid file, close NI MAX. When you open MAX again you can rename the camera.
