NI Package Manager Installer Crashes With Dependency Error -125032
Updated Jun 14, 2018
  • LabVIEW NXG
I am receiving an error when trying to install software from NI Package Manager.  The message says, "-125032: Invalid package structure at..." and gives a package name at a folder location.  How do I fix this issue?
This issue can occur when a dependency feed is changed.  If you go to the location the package is at, delete the package called out in the message, and then try reinstalling the software you are trying to install it should work.
