How to Communicate with UT-61C DMM with LabVIEW
Updated Jun 5, 2018
  • NI-VISA
  • NI-Serial
Other
UT-61C DMM
I want to communicate with a UT-61C DMM using LabVIEW, how can I accomplish this?
To communicate with the UT-61C DMM using LabVIEW, you must have NI-VISA installed. The serial parameters for the communication are as follows:
  • Baud Rate: 2400
  • Data bits: 8
  • Parity: Odd
  • Stop bits: 1
  • Flow control: None
  • RTS State: Unasserted
With this serial settings, the DMM will periodically send a serial message. You can use the attached VI to read the messages sent by the DMM.
The protocol used by the UT-61C DMM is not officially documented, it's up to the developer to decipher the messages sent by the DMM.
