NI-9244 Line to Line Measurement Gives Incorrect Value
Updated Jun 5, 2018
  • NI-9244
Other
NI-9244
I am following the connection diagram found on the Getting Started Guide for a Line to Line Measurement, but I am having an incorrect or unexpected measurement.
As seen on page 24 of the Geting Started Guide, to convert a Line-Neutral Measurement to a Line-Line Measurement, you need to calculate the difference between the analog input channel's readings.
This behavior is due to the internal connection of this device, which takes measurements respect to an internal reference, as seen in page 4 of the NI-9244 Datasheet.
