Low-Profile Bracket Not Included in My MXI PCIe Card's Kit
Updated May 5, 2025
  • PCIe-8381
I need the low-profile bracket to connect a PCI or PCI Express card to my computer. In the manual, it says that the bracket is included in the kit, but I can't find it. Also, I don't see a part number to order a replacement.
The bracket is a small piece of metal that can be easily lost or thrown away when disposing of the packaging, so please make sure that did not happen in your case. If you did not receive it, please contact Support so a Technical Support Engineer can assist you with this issue.
