Using Start And Stop Parameters In Word Format Text VI
Updated Jun 5, 2018
I would like to know which parameters or units to use in the Start and Stop Inputs on the Word Format Text VI
You just need to choose the range in which your word or words would be contained, counting the first letter of the document as 0. Every ASCII character will be taken into account on the range, including spaces, tabs, carriage returns and end of lines.
These parameters set the ranges for the words you would like to change the format. This counter is 0 indexed, which means that the first letter has the position value of 0. If you leave one of the parameters blank, you will get an error, which means you have to set a range and can't leave one of those terminals unwired.
