Error -2147287008 Occurred When Opening a Microsoft Access Database
Updated Oct 1, 2018
  • LabVIEW Database Connectivity Toolkit
I tried to open a Microsoft Access Database from LabVIEW using a UDL file I created programmatically and the following error occurred:
This error occurs when the file reference used to programmatically create an UDL file is not closed before trying to open the Microsoft Access Database. The following snippet shows an example of a LabVIEW code that can be used to programmatically create an UDL file.
