This problem occurs with LabVIEW versions prior to version 2012 on computers with 32 or more virtual cores. The number of cores refers to the number of cores reported by the operating system, so a CPU with 16 physical cores and Hyper-Threading Technology enabled already exceeds this limit. You can chose any of these solutions:
- Upgrade your LabVIEW installation to version 2012 or newer.
- Disable the Hyper-threading Technology in your computer's BIOS, if your CPU has less than 32 physical cores. Be aware this might impact the computer's overall performance as it lessens the computer's parallelization potential.
- If your computer allows it, disable cores of your CPU until you have less than 32 virtual cores. This impacts your computer's performance.
- Install LabVIEW inside a Virtual Machine that has less than 32 virtual cores assigned.
