该内容不适用于您选择的语言
I developed a LabVIEW class (.lvclass). In one class method I used Flatten To String Function to convert the class data to binary string, which I stored in a variable. In another method, I used Unflatten From String Function to convert this string to class again. This method is called in TestStand and everything works fine.I then built a Packed Project Library (PPL) and called the same method in TestStand by selecting it from the Packed Project Library . Running my TestStand sequence, I got the following error:Error 1527 occurred at Unflatten From StringLabVIEW: Attempted to read flattened data of a LabVIEW class that is not currently loaded into LabVIEW.
