I developed a LabVIEW class (
.lvclass). In one class method I used
Flatten To String Function to convert the class data to binary string, which I stored in a variable. In another method, I used
Unflatten From String Function to convert this string to class again. This method is called in TestStand and everything works fine.
I then built a
Packed Project Library (PPL) and called the same method in TestStand by
selecting it from the Packed Project Library. Running my TestStand sequence, I got the following error:
Error 1527 occurred at Unflatten From String
LabVIEW: Attempted to read flattened data of a LabVIEW class that is not currently loaded into LabVIEW.
