Is Cycle Multiplexing of the Startup Frame Possible in FlexRay?
Updated Jun 22, 2018
  • PXI-8517
  • LabVIEW 2017 Full
  • NI-XNET 17.0
I know that multiple frames can be sent at different rates on the same slot in FlexRay using FlexRay:Cycle Repetition property. But when I try to cycle multiplex the startup frame and other frames, timeout error -1074384886 occurs. Is cycle repetition of a startup frame and other frames possible in FlexRay?
Cycle multiplexing of the startup frame is not supported. Although you can use a startup frame like a normal cyclic frame and send it repeatedly, you can't cycle multiplex it.
