How Do I Log Different Sets of Data On Different Tabs Using TDMS?
Updated Jun 20, 2018
I have two sets of data and I would like to have each set of data in different columns of the same excel file. I would also like to have the timestamps in the first column of each sheet. How can I do this using TDMS?
You can use the TDMS Write function to group these. Each of the tabs correspond to the group name and the columns correspond to the channel name as inputs to the TDMS function. You can follow this example below to set this up.
