このコンテンツは設定された言語で表示できません。
Set Sampling Frequency Using compactRIO Scan Engine
Updated Sep 14, 2023
  • CompactRIO Chassis
  • CompactRIO Controller
In the scan mode (non FGPA) of the compactRIO, the sampling rate is normally limited at 1 kHz or less.  I am trying to use LabVIEW to program the compactRIO, how do I change the sampling rate?
If you plan to use the scan engine you must synchronize the timed loops in your code to this scan engine.
To synchronize a timed loop, right click the timed loop and select Configure Input Node. Here you should select synchronize to scan engine and use the period (number of scans) as a way of altering sampling frequency.
