NI-9207 Not Reading Voltage Correctly
Updated Jan 16, 2020
  • NI-9207
I'm using a NI-9207 to read in sensor data. When I check the voltage with my digital multi-meter (DMM), I see the voltage is an expected value. However the NI-9207 is reading a lower voltage than expected. My device gives a differential signal.
Devices which have differential signals require a 1 MΩ Resistor connected to the COM port.
See the NI 9207 Getting Started Guide for more detail.
