OOP Class with DAQmx Physical Channel Saves Properly to XML but Doesn't Load Properly
Updated Jun 6, 2018
In general, I have a DAQmx input inside a class. Creating an XML file from the class works fine (from a visual inspection of the XML file), but when trying to unflatten the file it will not read the value correctly and will return an empty value.
Place the class cluster inside an additional cluster then the DAQmx Physical Channel control saves and loads as expected.
