How Can I Import Data Being Read in LabVIEW into VeriStand
Updated Jun 26, 2018
  • VeriStand
I have a device that can't be read into the PharLap RT controller. I will have to use another computer to take those sensor readings. How can I take that data being read into LabVIEW and transfer it to VeriStand so that I can display both my RT data and my windows data all together?
There are a couple different ways to accomplish this.
If you want to continue using a VeriStand UI:
Create a VeriStand Model running on the RT. This model will simply be a shell and will only receive data from the outside. Then create a stand alone VI project to read the data and post the data to the model using "NI VeriStand - Set Parameter Value.vi" as the core.
If you don't need to keep using VeriStand UI:
You can use LabVIEW to build a UI that would control the VeriStand project via the built in API available. This option allows you to display all values from your hardware running on the Real-Time Target as well as the values from your windows sensor all in a single LabVIEW application.
An example of controlling a VeriStand project via LabVIEW can be found below.
Using the NI VeriStand .NET API in LabVIEW to Control a VeriStand System
https://forums.ni.com/t5/Example-Programs/Using-the-NI-VeriStand-NET-API-in-LabVIEW-to-Control-a-VeriStand/ta-p/3517370
