Error -1074102163, -1074102162, -1074126845 or -1074102157 When Using NI-DMM
Updated Jun 8, 2026
  • PXI Digital Multimeter
  • PXI Chassis
  • PXIe-4080
  • PXIe-4081
My PXIe-4080 DMM throws Error -1074102163, -1074102162, -1074126845 or -1074102157 whenever I access it through LabVIEW code, NI MAX or its soft front panel.
These errors are commonly caused by a corrupted NI‑DMM driver installation or an MXI/PXI compatibility issue. Try the following troubleshooting steps:
  1. Reseat the module: Move the PXIe‑4080 to a different chassis slot, starting with the slot closest to the controller, then test other available slots.
  2. Repair the NI‑DMM driver: Perform a repair of the NI‑DMM driver to resolve possible file corruption or missing components.
  3. Check MXI hardware: Replace the MXI cable and, if necessary, the MXI kit.
  4. Verify MXI‑Express BIOS Compatibility settings: Ensure the MXI‑Express BIOS Compatibility software is installed and configured correctly. Refer to the software readme for detailed installation instructions.
    1. Hardware switch: If the MXI-Express BIOS compatibility software is running on your computer, DIP switch 1 should be in the ON position. If not, DIP switch 1 should be in the OFF position.
    2. Software switch: If your computer is running the MXI-Express BIOS compatibility software, mode 1 should be activated. If not, mode 1 should be deactivated.
If this error occurs when using a PXI chassis connected to a PC via MXI, refer to the MXI-Express Compatibility and Connectivity Troubleshooting Guide for additional diagnostics.
If the system is powered by an Uninterruptible Power Supply (UPS), try adding a short delay before powering on the PC to ensure the PXI system initializes first.
