Maximum Wire Diameter Size for NI-9512
Updated Jun 18, 2018
  • NI-9512
I would like to purchase an NI-9512 but I am concerned about the maximum wire diameter that can be inputted into the DSUB Connector pins. What is the maximum diameter which the NI-9512 accepts?
The NI-9512 DSUB accepts a maximum wire diameter of 1.5mm. The pin assignments for this connector are below (taken from the specifications sheet).
