Create Or Replace Single Element In Datasheet
Updated Aug 10, 2018
How can I create or replace single element in datasheet? And my datasheet is saved in csv type.
To create/replace single element in datasheet  in LabVIEW, follow these steps:
  1. Read the datasheet using“Read delimited Spreadsheet.vi”,  and you should notice that the delimiter is ","
  2. Create or replace the element in datasheet using “Replace Array Subset.vi”, you need provide the row and column as an index
  3. Replace the 2D array in the datasheet using “Write delimited Spreadsheet.vi”
