Will My Camera Work with My Frame Grabber?
Updated Jun 6, 2018
  • PCIe-1427
  • PCIe-1433
I'm looking at purchasing a frame grabber from NI, and I'm not sure how to tell if they are compatible with my Camera Link camera. How can I tell if my camera will work with a particular frame grabber?
When checking a camera and frame grabber for compatibility, the main factors you have to keep in mind are:
  • Bit Depth- how many bits are used to represent each pixel?
  • Tap Geometry- in what order are the pixels being sent by the camera?
  • Bus Type- are you working with Gigabit Ethernet connections, or Camera Link Base, Medium, or Full?
If the camera and frame grabber match on those 3 fronts, they should be compatible.
