Can I Use an SHC68-68-RMIO Instead of A SHC68-68-RDIO2 Cable?
Updated Mar 26, 2025
  • PXIe-7820
  • SHC68M-68F-RMIO Cable
  • SHC68-C68-RDIO2 Cable
  • NI R Series Multifunction RIO
I have an R series card that is recommended to use a SHC68-68-RDIO2 Cable with but I want to use the SHC68-68-RMIO Cable for the form factor.  Is it possible to use the RMIO in place of the RDIO2?
No, there are differences in architecture, pin-out, and bundling that will not allow these cables to be swapped and work correctly.
