Can I Replace Real-Time Startup Application on CompactRIO Without a Resetting FPGA?
Updated May 31, 2018
  • cRIO-9068
  • cRIO-9033
  • myRIO-1900
Is is possible to change or upgrade Real-Time Startup Applicaiton on CompactRIO so that the FPGA is not interrupted and all Input or Output Channels are kept under control?
CompactRIO 903x allows you to change Real-Time Startup Applicaiton without interrupting FPGA execution. But restarting a CompactRIO-906x resets FPGA I/O to Default State.
Open FPGA VI Reference does not interrupt FPGA execution, if FPGA target is already running FPGA VI or bitfile, which is defined in Open FPGA VI Reference.
