How To Find The PXI System Programmatically in LabVIEW
Updated May 31, 2018
  • System Configuration
What is the best way to find my PXI system programmatically in LabVIEW?
The recommended way to find systems and hardware is by using the NI System Configuration API
The NI System Configuration API provides a common programmatic interface for users to find and configure devices and remote systems. The API serves as a programmatic mechanism to do most of the things that you can do from MAX.
You can find LabVIEW examples in the NI Example Finder under Hardware Input & Output >> System Configuration.
