Does The PXI-4130 Support Hardware Timing?
Updated Jun 5, 2018
  • PXI-4130
I would like to perform hardware timed sequence with the PXI-4130. Does the PXI-4130 support hardware timing?
No, the PXI-4130 does not support hardware timing. Any sequences or sweeps using the PXI-4130 have to be performed in software and have to be timed by software.
The PXI-4130 can acquire a fresh voltage and current measurement 333 µs. It can also issue an update every 333 µs. Therefore, the fastest source-measure loop rate that can be reached is 3 kHz. This is possible to reach as long as you have a reasonably fast machine with minimal workload.
Hardware-timed sequences allow you to change various parameters of the SMU such as output mode, aperture time, current range, transient response, at each step.
