Current and Voltage in a Single Analog Task
Updated May 30, 2018
I am trying to read or write both voltage and current on a single NI analog card. Is this possible?
Can I do current and voltage acquisition in a single task?
Current and voltage are both variations of the "Analog" task type whether it be analog input or analog output. As such, they are able to share a timing source and thus can be used together in a single task.
In LabVIEW, this can be accomplished using channel expansion using the DAQmx Create Virtual Channel VI as in the following example:
Create Multiple Analog Measurement Types Task in MAX explains how to create these types of tasks in NI MAX.
When using multiple channels in a single task, data in or out will be in the form of an array with a new column for each channel.
Different task types can not be included in a single task. For example analog input and digital input cannot be included in a single task because they cannot share the same timing source.
