Finding the Device and Channel Name(s) of a IVI Device
Updated Apr 4, 2023
  • IVI Compliance Package
How do I find the device and/or channels names of an IVI Device?
IVI devices typically support both physical channel names and virtual channel names. Both can be used in LabVIEW. Follow these steps to fine the channel's name:
  1. Launch Measurement & Automation Explorer (NI MAX)
  2. Navigate to My System » IVI Drivers » Logical Names
  3. Locate the device to be used in LabVIEW. Be aware that the Logical Name is case sensitive; IVI drivers distinguish between upper case and lower case letters.
  1. Note the Driver Session and navigate to it by clicking Go To.
  2. In the driver session, open the Virtual Names tab. If the channel name used in LabVIEW is a virtual channel, find its Virtual Name here and verify its spelling. Be aware that the virtual channel names are case sensitive as well. In case the channel in use is not a virtual channel, continue with step 6.
  1. If a physical channel name is used in LabVIEW, proceed to the Software tab, find the Software Module section, and click Go To.
  2. Here, open the Physical Names tab and find the Physical Names of the device's channels. Verify that the channel name used in LabVIEW equals the Physical Name listed here.
