Connect a DMM With the TB-2605 Isothermal Terminal Block
Updated May 30, 2018
  • TB-2605
  • PXI-2503
  • PXI Digital Multimeter
I am using the TB-2605 Isothermal Terminal Block with my PXI 2503 Switch device and I wish to connect it to my NI Digital Multimeter device in order to use it as relay scanner. What is the cable I need?
You have to use the P-3 Probe Set
The P-3 Probe Set cable only realizes an electrical connection between the DMM and the Switch devices: the synchronization within the two boards will be ensured by the PXI chassis backplane the two boards are inserted into.
