Configure the Channel Coupling Mode of NI High-Speed Digitizers
Updated Mar 19, 2019
  • PXI Oscilloscope
  • Oscilloscope Device
  • NI-SCOPE
How can I configure the channel coupling mode of NI high-speed Digitizers (Oscilloscope)?
Please make sure that you have installed the NI-SCOPE driver.
In NI-SCOPE Soft Front Panel:
If you are using the NI-SCOPE Soft Front Panel, you can configure the channel coupling mode as shown in Figure 1.
Figure 1. NI-SCOPE Software Front Panel
In LabVIEW VI:
If you are programming for NI High-Speed Digitizers in LabVIEW, you can use ​​niScope Configure Vertical.vi to configure the coupling mode by specifying the vertical coupling input, as shown in Figure 2.
Figure 2. niScope Configure Vertical.vi
