Archived:Using Third-Party Drivers in LabVIEW NXG
Updated Oct 20, 2022
  • LabVIEW NXG
I have a third-party instrument driver written in LabVIEW, can I use this driver in LabVIEW NXG?
  • Instrument drivers must be written specifically for LabVIEW NXG to be compatible with LabVIEW NXG. Many third-party drivers have been migrated into NXG and can be found by searching in NI Package Manager.
  • To Download and Install LabVIEW Plug and Play Instrument Drivers in LabVIEW NXG, follow this tutorial.
  • If a driver has not been written for NXG, you can request from the third-party itself that they release an NXG driver or migrate the driver into NXG using the NXG Code Conversion Utility.
LabVIEW drivers are basically LabVIEW VIs that are built using lower level calls such as VISA or NI-Serial. Version compatibility of LabVIEW drivers can be treated very similarly to compatibility of any VI.
