Easy Print VI Panel Print Resolution Is Too Low
Updated Jun 15, 2018
I am using the Easy Print VI Panel or Documentation VI to print data from my front panel. However, the image that I printed appears to be low resolution and difficult to read.
In the printer options of the VI, choose Standard for Printing Method. To change this, right click on the "Layout Options" input and click Create -> Control.   Printing Method is located inside the Printer Options cluster. If this does not change the output, keep changing different inputs in the layout options until the output appears correct.
The Standard Printing Method allows the Operating System to choose its preferred drawing method. This is why other settings for this option may vary in output quality from computer to computer.
