Why the Default Directory.vi Shows a Different Path When It Runs as LabVIEW Code Than When It Runs as Executable
Updated Jun 5, 2018
When I create an executable using Default Directory.vi it has a different behavior when it runs as LabVIEW Code.
The Default Directory running as LabVIEW code shows the LabVIEW installation directory. When you use the same VI in an executable it will show the folder where the executable is located.
