Using PCIe-8236 as a Conventional Ethernet Port
Updated Jun 5, 2018
  • PCIe-8236
I have a PCIe-8236 Frame Grabber device. The card has two Ethernet ports. I want to use one of them to acquire images from a GigE Vision camera and the other one as a conventional Ethernet port to connect to a local area network.
Is it possible?
Yes it is. The NI 8236 provides two standard Gigabit Ethernet ports (Port 0 and Port 1) to acquire images from GigE Vision cameras.
Since these port support the IEEE 802.3 standard you can use it in networks with this physical layer.
The PCIe-8236 is supporting 10BASE-T, 100BASE-TX, 1000BASE-T communication standards on an RJ45 interface.
Please refer to the User Guide and Specifications linked below.
