The correct communication method depends on how the printer and its driver expose the device to the operating system. A USB connection does not necessarily mean that the printer communicates through a serial COM port.
Before developing the LabVIEW application, connect the printer and determine how it appears in the operating system.
Scenario 1: The printer appears as a COM port
Some printers expose a virtual COM port, either through an integrated USB-to-serial interface or an external USB-to-serial converter. In this case, the printer can generally be treated as a serial device.
To communicate with it:
- Download and Install NI-VISA.
- Install any driver required by the printer or USB-to-serial adapter.
- Connect the printer to the computer.
- Confirm that a COM port appears in the operating system's device manager.
- Obtain the serial-port settings and command protocol from the printer manufacturer.
- Use NI-VISA in LabVIEW to configure the serial port and send the required printer commands.
Relevant examples are available in the NI Example Finder. In LabVIEW, select Help >> Find Examples, search for VISA, and review examples such as:
- Simple Serial.vi
- Continuous Serial Write and Read.vi
Scenario 2: The printer appears as a USB device rather than a COM port
Some printers do not create a virtual COM port. They may appear as a USB printer device, a vendor-specific USB device, or another USB device class.
In this scenario, the serial-port procedure above does not apply. Determine which communication mechanism the printer supports, such as:
- A manufacturer-provided driver or SDK
- A documented USB protocol
- A printer queue managed by the operating system
- Network communication
- A vendor-specific API
- A command language sent through a supported transport
Consult the printer manufacturer's documentation or technical support to identify the supported interface and appropriate programming method.
Do not replace an existing printer driver with an NI-VISA USB driver unless the printer manufacturer documents direct USB RAW communication and the effect of changing the driver is fully understood.
Printer command languages
Many label and industrial printers support a manufacturer-specific command language. To use features exposed by that language, the LabVIEW application must send correctly formatted commands through a transport supported by the printer.
The Report Generation Toolkit supports report and document generation workflows, but it may not expose every printer-specific feature available through a manufacturer's command language. For access to those features, use the communication interface, SDK, or API documented by the printer manufacturer.
LabVIEW does not provide a universal communication API for all USB printers. The correct implementation depends on the printer model, installed driver, operating-system enumeration, supported transport, and manufacturer-defined protocol.
Before selecting NI-VISA or another LabVIEW interface, verify:
- How the printer appears in the operating system
- Whether it creates a COM port
- Whether the manufacturer provides an SDK or API
- Whether the printer supports direct command-language communication
- Which transport the manufacturer supports for those commands
