Yes, the Vision Development Module is required to allow VBAI to generate LabVIEW Code. To migrate your VBAI Inspection to LabVIEW code:
- From your VBAI Configuration Interface, go to Tools » Migrate Inspection to LabVIEW.
- A dialog box will appear, which will allow you to choose the version of LabVIEW and NI Vision you will use to create the VI, as well as the folder where the LabVIEW VIs will be created. Click OK to start the migration process, and it will proceed to create the LabVIEW VIs.
- Once finished migrating, A Dialog box will appear informing you that the VBAI Inspection was successfully migrated to LabVIEW.
Note: Make sure that the bit versions between the VBAI and LabVIEW match. Otherwise, migration is not possible. For example, if you want to migrate to LabVIEW 2018 64-bit, you need the VBAI 64-bit.
