Fixing Data Loss While Logging Data in a Real-Time Target
Updated Feb 21, 2019
  • LabVIEW Real-Time Module
I am logging data coming from a global variable to a file every certain period in a Real-Time Target. However in the resulting file I am observing gaps in the data that is being written to the file. How can I fix this?
First of all, if possible, data logging in a real-time target should be reduced or eliminated altogether.
If this logging is unavoidable for a particular application one way to fix the data loss in this case would be to implement a producer-consumer architecture. In the producer loop the data should be written into the queue. In the consumer loop the data will be dequeued and logged into the file.
Communication between real-time target, host PC and FPGA can be achieved in a lossless manner using network streams
For more general information on data logging in an RT target refer to Best Practices for Target File IO with LabVIEW Real-Time
