LabVIEW FPGA Module Appears as Not Present Even Though It Is
Updated Aug 14, 2018
  • LabVIEW FPGA Module
I am trying to open a VI that uses some FPGA functions. However when I open it I receive a message that the LabVIEW FPGA module is not present. This happens even though I have that module installed and activated in my computer, as I have checked in the License Manager.
The version of the LabVIEW FPGA module installed on the computer should match the version of LabVIEW used to open the VI that contains the FPGA functions.
Note that there is currently no 64-bit version of the FPGA module, so programming the FPGA will require to use the 32-bit version of LabVIEW.
