Modular Data Acquisition
High-Performance Test
I want to simulate a resolver with LabVIEW in the FPGA of my R-Series PXI card or my CompactRIO, is there a program that does this?
The Resolver Signal Simulation and Measurement in LabVIEW FPGA example program can be used to simulate a resolver. It can run on both a CompactRIO or a PXI target.
In order to use this example program you should:
