If you have the LabVIEW Development System in the computer you can follow the next steps:
- Right-click the CompactRIO in the LabVIEW project and select Deploy All.
- If you are using an executable, you can then rebuild it by right-clicking it below build specifications and selecting Rebuild.
If you do not have LabVIEW on your computer, you can follow these steps :
- Go to NI Measurement and Automation Explorer and detect the cRIO.
- Expand the cRIO under remote systems so that the Software is displayed.
- Right-click Software and Select Add/Remove software.
- Select your LabVIEW Real-Time Module version and click OK.
- Go to the Remove tab, check the NI Scan Engine and click Review Changes to remove it. By doing this, the cRIO will be only in FPGA programming mode.
- Once this is done, you can redeploy the executable and the error should no longer appear.
