SystemDefinition .NET Object Is Not Released After Closing the Reference
Updated Aug 9, 2018
  • VeriStand 2015
I need to operate on .nivssdf files from LabVIEW application using NationatInstruments.VeriStand.SystemDefinitionAPI(15.1.0.0) .NET assembly. I use .NET constructor SystemDefinition(String nivssdfFile) to load System Definition file and then Close Reference" to unload it.
I noticed that after creating EXE application .NET object is not unloaded properly after using Close Reference
It cause that memory usage is increasing drastically.
This behavior was observed for Veristand 2015. It’s known that in Veristand 2017 this problem was fixed and after upgrading your project to this version the problem will not appear anymore.
